-   600 Modifications (https://cbrforum.com/forum/600-modifications-41/)
-   -   Unique mods (https://cbrforum.com/forum/600-modifications-41/unique-mods-12765/)
CBRMadman Apr 18, 2006 10:44 PM
Unique mods
Has anyone desingned their own mods for their bike? Just curious....... looking to find something unique other than the usual stuff.
liquid_iq Apr 21, 2006 03:56 PM
RE: Unique mods
yes but all mine are unfinished. in the works are:
1. custom undertail, retains stock taillight, uses stock undertail. hint: lots of cutting and plastic welding! i'll probably have to relocate the lock far away and fabricate longer cable
2. led taillight retaining stock taillight housing
3. semi-flush mount lcd rear turns, mounted in tail, like some recent bikes have stock
4. stealth tail/turns using led's BENEATH the paint in tail (concept and design stage)
5. 1000rr HESD unit retrofit
6. 06 GSXR mirrors (w/turns) retrofit - i may not be able to pull this one off though, the mounting angle is way different even though the bolts almost match up
7. custom no-cut frame sliders that actually work (concept and design stage)
8. dual headlights using two low-beam reflectors and dual-filament bulbs OR high/low xenons (used headlights are too expensive for me to attempt this one so far - since i'll need TWO)
9. comfortable single seat with custom cowl (concept stage) note: corbin has a new seat that is what i was thinking, but their "smugglers trunk" is downright ugly
10. gear indicator using wasted space on stock lcd (wishful thinking stage)
hopefully, now that all my secrets have been revealed, they will all sound too crazy for others to attempt, and i can retain all the glory for myself. if i'm successful, that is.
sodamninsane Apr 21, 2006 08:30 PM
RE: Unique mods
carbon fiber block off plates
carbon fiber solo cowl
DIY fender eliminator w/ plate light
http://www.msu.edu/~gillet38/Bike/So...bikefinnet.jpg
http://www.msu.edu/~gillet38/Bike/So...ikefinnet2.jpg
http://www.msu.edu/~gillet38/Bike/12105/ledplatenet.jpg
http://www.msu.edu/~gillet38/Bike/12105/rearnet.jpg
josho66 Apr 21, 2006 08:48 PM
RE: Unique mods
I haven't done it yet but I really like the guys that take out the stock plastic in the air intakes and put in mesh. Looks really good.
mpsoldier Apr 25, 2006 02:26 AM
RE: Unique mods
do scratchs count?
