-   600 Modifications (https://cbrforum.com/forum/600-modifications-41/)
-   -   Top speed (https://cbrforum.com/forum/600-modifications-41/top-speed-98914/)
randyjoy Feb 18, 2010 06:18 PM
Originally Posted by RedEIKO0713 (Post 884949)
how does a speedo healer actually work? anyone know or have experience?
I have one. It connects in series to the speed sensor and also to power.
You really need to calibrate it with GPS first (there are other methods, but GPS is best), so you have a ACTUAL speed and your INDICATED speed. For instance, indicated 60 on my guages, actual 56 on the GPS. You then put that into the Speedohealer calculator, and it would yield (in this case) a -6.7% calibration value. You program that into the Speedohealer.
In operation, the speedohealer reads the pulses coming from the electronic speed sensor and decreases or increases the pulse interval by the calibration value and sends that pulse to the speedometer.
philthethrillohio Feb 18, 2010 06:53 PM
im having my bike dynoed again and they were just going to do the speedo healer with the dyno. you think that would be just as acurrate if not more then the gps?:icon_shrug:
randyjoy Feb 18, 2010 10:44 PM
Actually, that is the best way because it is sustainable. The GPS is harder to hold a consistent speed for the reading(s). I said GPS was the best only because of the lack of availability of a dyno to everyone, but the dyno is optimal.
RedEIKO0713 Feb 19, 2010 07:40 AM
Ok, so to calibrate ideally you would do 2-3 runs with a gps to calculate error then run sustained speed dyno runs to maintain and program? How much does a speedo healer cost? The cheap garmins which are pretty accurate and follow you pretty closely are only 100 bucks nowadays, although I'd imagine some people don't want an extra gadget to maintain along with the bike.
Joy you have any pics posted anywhere of your 954?
randyjoy Feb 19, 2010 09:25 AM
If you've got a dyno, that's all you need to calibrate. No dyno, use GPS.
They're around $100, can find them on sale for less. Nice in that is makes your stock speedometer accurate (though it will change the odometer, making it inaccurate) and isn't another gadget to worry about.
I only have some lousy phone pics and a few track pics of the 954. My good ones got zapped in a crash. I'll see what I can find.
johnnyh Feb 19, 2010 05:00 PM
You know I was doing some research and a gps is not as accurate as claimed to be unless you are on level ground and going in a straight line. Johnny
RedEIKO0713 Feb 23, 2010 08:48 AM
2 Attachment(s)
Attachment 58211
Attachment 58212
yep, a gps probably isn't 100% accurate but I believe it's the most accurate and versatile way to measure speed we have. you could probably use laser to make an even more accurate system but that'd only work in a straight line. and since gps units are linked to satellites the "triangulate" the receiver than i'm sure going any other way than dead straight would produce an even larger error. my bike did 144mph bouncing off the limiter, a few other guys went and wow, do not buy those jardine megaphones for the new gsxr's.
would've uploaded a video but the files wouldn't play on the camera or the comp when done for some reason?
livewakesnow Feb 26, 2010 11:37 AM
ive hit 165-167 on my 2006 cbr600. no power mods. just me and i-10 going through Indio and Coachella. Prolly had a back win. That was all I could get out of here and it was a push.
randyjoy Feb 27, 2010 01:44 AM
Depends on the sampling rate and the number of satellites you've gotten aquired, lowering your EHPE (Estimated Horizonal Position Error). A GPS actually designed for mounting on a bike, such as the GPXPro from xtracing.com, is very accurate, where as your $60 TomTom isn't. Of course, the GPXPro is nearly $700.
Indicated or actual?
