sprocket change
if you change the sprocket, will the odometer be off then?
RE: sprocket change
i beleive only if you change the front sprocket.
RE: sprocket change
ORIGINAL: mumbless89 if you change the sprocket, will the odometer be off then? |
RE: sprocket change
If you change the front or rear sprockets, meaning the number of teeth. This will change your odometer and speedo. It is similar to plus sizing wheels on a car and not changing the tire size. You can however change the style of sprocket from 525 to 520, keep the same teeth sizes and benefit from weight savings (unsprung... the best kind).
| All times are GMT -5. The time now is 05:10 AM. |
