mods
Old Sep 18, 2008 | 09:06 AM
07white600rr's Avatar
Default mods
so i want my bike to have more power. im guna either do a full exhuast or slip on n a pc3. and got some tips on how to let more air in so guna do that quick mod. but what else can i do for parts to get more power. i cant seem to find any engine kits (piston,cams,plug etc etc) can anyone help or throw ur 2 cents in? thanks
Old Sep 18, 2008 | 09:14 AM
PlayfulGod's Avatar
Default RE: mods
regear it -1/+2. It will put the power where you can feel it more.
Old Sep 18, 2008 | 11:12 AM
shoortbuss's Avatar
Default RE: mods
http://www.edecals.com/Flags/rallyst.htm
Old Sep 18, 2008 | 12:19 PM
Default RE: mods
thanks for the links guys. if i regear it wont the speedo be off? and wut does each on mean? (sorry for the noob question, know more bout cars than bikes)
Old Sep 18, 2008 | 12:51 PM
crashkhanman's Avatar
Default RE: mods
-1 means going down 1 tooth in the front sprocket on the bike. +2 means going up 2 teeth in the rear sprocket. Stock teeth count for your sprockets on the '07 is: 16 teeth front / 42 teeth rear...... so if you went with his recommendation you'd buy a sprocket for the front with 15 teeth and a sprocket for the rear that has 44 teeth. The Speedo will be off considerably with a sprocket change like that. However, they do sell the "Speedo-Healer" that can correct the change. Going down 1 tooth in the front sprocket is roughly equilvant(sp) to going up 2.79 teeth in the rear.
This is by far the best thing I did for my bike. You loose top-end speed but the useable( I don'tever go 140+mph on the streets)gains are well worth it.
Old Sep 18, 2008 | 01:34 PM
PlayfulGod's Avatar
Default RE: mods
[sm=icon_rofl.gif]
Old Sep 18, 2008 | 01:48 PM
Default RE: mods
so how much does that peice cost? (speedo healer) and wut if also wantd to kinda of keep my top end? wuld i just do the front or just the rear?
Old Sep 18, 2008 | 01:53 PM
PlayfulGod's Avatar
Default RE: mods
ORIGINAL: 07white600rr
a speedo healer runs about $100. Either will take away from the top end, which if you really think about it you never see no way (or shouldnt unless you are one of those...).
