Help!!!
Old Jun 27, 2006 | 01:12 AM
Riding Red's Avatar
Default Help!!!
I am installing LEDS and I bought a flasher relay for a Honda. I was told they would fit. That isn't my problem...yet. I can't find the old flash relay. Where is it?
Old Jun 27, 2006 | 01:58 AM
kaynott's Avatar
Default RE: Help!!!
good question.
Old Jun 27, 2006 | 02:20 AM
Riding Red's Avatar
Default RE: Help!!!
Nobody knows? aaaaaaahhhhhhhhhh. I am so frustrated. Ok what did you guys use then to fix your flash rate and where did you get it?
Old Jun 29, 2006 | 03:22 PM
Chips Ahoy's Avatar
Default RE: Help!!!
Ummm, If you have a 600RR, the flasher relay is built into the dash panel. The only way I know to correct the flash rate would be to wire an inline resistor to each side. Look at this page for more info: http://www.customdynamics.com/loadequalizer.htm Check out item #4810 Load Equalizer.
Old Jun 29, 2006 | 03:51 PM
Riding Red's Avatar
Default RE: Help!!!
Thanks, I found that out the hard way and just returned the relay that the dumbass sold me. I decided not to use the equalizers because the blink rate is fast only part of the time but it still flashes at a decent rate.
