headlight mod
Old Oct 26, 2010 | 10:30 AM
600f4ilover's Avatar
Smile headlight mod
just wondering on an easy way to mod the headlights so that both of them come on..I am tired of people saying that I have one headlight out. I have a 2006 Honda CBR 600 F4i
Old Oct 26, 2010 | 11:32 AM
R Dub's Avatar
October 2011 ROTM
not to be a jerk but the easy way is to turn on your brights. Other than that no. There is a way to make it where both are on but it is no easy. I ride with my brights on all the time. Who cares it is pisses someone off. I would rather they be pissed off at me and not kill me then not see me and run right into me.
Old Oct 26, 2010 | 12:35 PM
Musicmanmk2004's Avatar
Theres actually a really simple way. pull your front end off the bike. set it to where you can see the wires and look at the two headlight plugs. alls you need to do is that the high beam power wire and splice it into your low beam power wire. that way it has constant power no matter what. but like ^ said you can just ride with your highs on, its the same effect.
Old Oct 26, 2010 | 02:39 PM
Thanks very much!!! sounds good to me!! I do ride sometimes with my brights on...I get the odd flash from cars....as long as they can see me its all good!
Old Nov 5, 2010 | 12:07 AM
The__Rider's Avatar
With HIDS will this burn out your bulbs quicker if they both are always on? I was told that HIDS burn "hotter" and generally do not last as long as a stock bulb. So, I imagine having them on longer than normal would wear them out.
THanks
Old Nov 6, 2010 | 11:23 AM
THanks
actually its the opposite. HID's do burn hotter if im thinking correct, but HIDs have a way longer life then a halogen bulb. so running both wont hurt a thing. what hurts HID's and shortens the bulb life is if you turn them on and off repeatedly. that will burn up the igniter and wear out the bulb.
cmartino88
Aug 1, 2012 06:39 AM
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
