f4i headlight swap with 98f3
i just got a good deal on a 98 cbr f3 and was wondering if it is possible to put a 2002 f4i headlight conversion on my bike to give it a newer look. Also will i have to also go with the gauge pod from the f4i to make this work. If i go with an electronic gauge how hard is it to wire it up to take advantage of all the options ? One more thing how hard would all this be ?
RE: f4i headlight swap with 98f3
I am trying to remeber eveything on my F3 but You could do it. You have to get an F4 gauge not an F4i. advantages?? You arent getting much other than looks. You could get a F4i nose fit it to your F3 and simply wire up the lights. You would have to change the fairing stay bracket a little. I would get the nose done first and you can worry about gauges later. It would be a lot of work, fitting the fairing right would be the hardest thing. I personally wouldn't do it.
