F4i Flushmount help please
Old 09-24-2006 | 05:09 PM
Dave K's Avatar
Default RE: F4i Flushmount help please
Pugetpower, Thanks, I will check them out. What did you go with?
Old 09-25-2006 | 08:42 PM
Pugetpower's Avatar
I got them from the local store in Renton WA. Chapparel probably has the same ones. The are very short stalks with nice rubber vibration pieces. The 3-wire was a Lockart Philips and the 2-wire (rears) were
some other brand that looked identical. They must all buy from the same outfit in China. They aren't LED, but very bright, which I wanted. Since the wernt LED, the flash rate stayed the same (slow blink).
Old 10-16-2006 | 07:10 PM
hopkinslax12's Avatar
though you've probably figured this out by now---or otherwise purchase a different set of flushmounts.....your problem IS the ground wire....you aren't using it. you NEED TO USE YOUR GROUND from the bike as one of the two wires to connect to the blinkers, connect the black wire on the blinker to your ground on your bike, and then one of the other two wires to the white one. then try the turn signal. if it flashes, you found the blinker wire, if it stays solid, then you found the running light wire....simple as that. PM me if you have any questions
mikemcw
10-26-2008 09:19 AM
n1philli
06-25-2008 02:50 AM
BRRandon
01-04-2008 12:30 AM
burga
09-10-2006 01:48 AM
kash
06-22-2006 11:11 PM
Quick Reply: F4i Flushmount help please
