f2 to f4i gauge conversion help ..
hello there friends in mew to this place though i have been reading alot from here. i decided to do a gauge conversion on my f2 600 .
everything works ,except the speedometer , i placed the sprocket cover with sensor and also i have a speedo healer v4 already but im not sure how to wire it to the sensor and to the guges . i tried wiring it but it does not register anything on the meter eaven after setting the speedo healer's calculations . can anyone help me out here please ? i looked around but found nothing relating to the speedo healer's wiring layout and how to wire it to the gauges and sensor harness |
I moved your thread over here from the "how-to" section. That section is only for write-ups on how to do something and not questions.
Hopefully you'll get some exposure over here, or maybe try the F4i or F2 areas? |
Thank you I hope I find the help cause I'm depressed and frustrated I can't figure it out .
