Embarassed to ask
RE: Embarassed to ask
Put mine on a week or two ago, just took a couple hours(most of that spent being a puss about it not wanting to drill out the fairings but they came out nice, and hopefully I won't need to use them but if I do they're there...
As far as the swingarm sliders, is there a place on the 99 f4's for those to mount into or do you have to have tabs welded and tapped?
Jason
Jason
ORIGINAL: woodyracing
i use vortex sliders and have crash tested them several times, they are awesome
any delrin sliders other than the no-cut ones will be fine (no cut sliders are crap, don't even go there)
If I were you Lowcash I would put a crash cage with sliders, it'll protect your bike better than just sliders IMO
Also get someone to weld some sliders (spools) for your swing arm, there's a website that does that for you if you buy their spools I don't recall the name though[sm=imsorry.gif]
There are 3 posts here (at least) saying that NO-CUT sliders are crap, but absolutely NO explanation why. WHAT makes a no cut slider worse than the standard ones?
As far as I can tell, they just have a deeper "mounting peg" that goes to the base of one of the engine bolts, whereas the standards have a wide base section (and therefore require cutting of the fairing).
Can anyone explain exactly why no-cut frame sliders are inferior???
Thanks!
Thanks!
