Dim Lights
Need some help. I got new headlights (Xeon lights) and a new Running light (Xeon also) including new LED Turn siganls front and rear, but they go dim when I put my high beams on. looks like not enough power is going through. what can i Do?[:@]
RE: Dim Lights
I dont know if this would do anything but you could try putting them all to seperate grounds/
Not sure. Daniel Thompson |
RE: Dim Lights
That and double check to see if you that you connections are clean / tight.
| All times are GMT -5. The time now is 10:09 AM. |
