-   600 Modifications (https://cbrforum.com/forum/600-modifications-41/)
-   -   190 on a 600RR? (https://cbrforum.com/forum/600-modifications-41/190-600rr-57801/)
be vertical Jan 16, 2008 02:26 AM
190 on a 600RR?
I just want to know if I can fit the 190 tire on the back of my 07 600RR? I know its pretty useless but I think it will look dope with my newly polished wheels. If it will fit between the swingarm, will it fit on the stock wheel. If yes, will it negatively effect ride or performance in any way? Thanks to the helpers, bah to the preachers.
camaro_forums Jan 16, 2008 02:57 AM
RE: 190 on a 600RR?
hmm,I was actually wondering the same thing the other day. Hopefully we hear from someone who has done it
bluej511 Jan 16, 2008 11:23 AM
RE: 190 on a 600RR?
a 190 fits from what i understand but your decreasing lean angle or something but better straight line traction.
crashkhanman Jan 16, 2008 12:49 PM
RE: 190 on a 600RR?
Yes it would fit....BUT...You would have a slower turn-in then you have now and the ride would not be very stable with the extra width and sidewall height. Not recommended.
bigcha40 Jan 16, 2008 12:53 PM
RE: 190 on a 600RR?
iv also heard that it will bend the lip of the rim over time if its a stock 600 wheel with a 190 on it
telgren Jan 16, 2008 02:23 PM
RE: 190 on a 600RR?
the bike was designed for those exact tire sizes... you are talking about making major differences in how it performs/handles. I enjoy taking a lean, so why move the dynamics?
knightslugger Jan 16, 2008 05:09 PM
RE: 190 on a 600RR?
190/55 is doable. some like it. some dont. either way, it's safe to do. many a racer choose this over a 180.
be vertical Jan 16, 2008 09:27 PM
RE: 190 on a 600RR?
AAH! conflicting opinions.. which is what I expected. Is it safe or not, and will I lose any ability to get-er down low?
aaron1085 Jan 16, 2008 09:31 PM
RE: 190 on a 600RR?
wider tire = lean angle affected
Jason748 Jan 16, 2008 09:48 PM
RE: 190 on a 600RR?
From a racers standpoint...
The 190 weights more...enough to make a noticable difference.
The 190 offers more "side traction".
The 190 requires a different suspension set-up to work.
The 190 requires moreturn-in effort and is not as "flickable" side to side.
On tracks with long, flowing, fast corners, a 190/55 works well becuase of the additional side traction. But on shorter, tighter more techinical tracks the 180 works better becuase you're spending more time going side to side.
I've tried it, didn't really like but could feel in some corners where it would help, BUT Inever set my racebike up for it...
It's safe to do, but unless you can run a fairly quick race pace, I doubt you'd notice any real traction difference. At most you'd probablynotice the additional pressure required during intial turn-in. Stay away from the 190/50 unless you go with a 6" rim, the 190/55 is a little pinched on the 5.5" rim, but a 190/50 is really pinched on a 5.5" rim.
ORIGINAL: bigcha40
Who ever told you that should be smacked up side the head, tires don't bend rims... incompenent tire changers, pot holes and crashes bend rims.
