-   1000 Modifications (https://cbrforum.com/forum/1000-modifications-42/)
-   -   power commander (https://cbrforum.com/forum/1000-modifications-42/power-commander-15523/)
kryptonite_cycle May 29, 2006 11:58 AM
power commander
if you buy only a pc, what other mods do you need with the pc? do you need a cooler stat, exhaust...etc?
deezuhl May 29, 2006 12:37 PM
RE: power commander
pc3 will work on a stock bike. cleans up the rev range and give you a bit more power in certain rpms.. i would get a full system and filter tho with it if i were you so you could actually see some real power gains..
kryptonite_cycle May 30, 2006 12:28 AM
RE: power commander
ty...got the k&n but i have to install it. gotta wait for the exhaust too much $$$$
blade17fire May 30, 2006 03:21 AM
RE: power commander
i suggest u get all the things u want install first b4 u get the PC III..ie; slip-on/full system,filters,flapper mod to say the least..only den u get the PC III and set it up..dat way u'll save costs by nt remapping over and over again..
Seltorque May 30, 2006 09:09 AM
RE: power commander
I have seen somewhere on the web that if your going to spend money on the bike. They reckon the first mod shoould be the PC. Even on a complete stock bike. You will notice a difference in the fuelling of the bike. It will be alot smoother to start of with.
blade17fire May 30, 2006 01:31 PM
RE: power commander
yes seltorque its true..the factory settings is not optimise to everyones' climate or sea level or watsoever. u can get the PC first to get the fuelling rite..but wat if u buy a slip-on after dat..filters..stacks..etc..etc..dun u have to set it over and over again? it costs money my fren..lots of it.The bike will run find in most cases with all the mods done except for some minor fuelling glitches..once u're done with modification the air/fuel components..den get a PC and set it up once and for all...
Just my 2 cents worth..:) i'm not arguing wif u seltorque bro...:D
blade17fire May 30, 2006 01:42 PM
RE: power commander
sorry to hijack this thread...
hey seltorque..look like u have a PC III. u said b4 there is no damn dynamometer in ur country..why dun u come on down to s'pore and have a custom map done?? its worth the trip..only den will u live up to Honda's "Power of Dreams" LOL..:)
Seltorque May 30, 2006 02:23 PM
RE: power commander
ORIGINAL: blade17fire
Yeah I have thought of that. As you mentioned elsewhere you have 4 tuners within a 20km radius. I may try to convince my buddies to all ride up. but this will have to be done after the rain season we are having at the moment. Which is a bit of a bummer!!!!
