PC III Accelerator Pump
Old May 24, 2006 | 12:00 PM
blade17fire's Avatar
Default PC III Accelerator Pump
I understand there's a free download for the accelerator pump mod for PC III usb users..My questions are, what good does it make and what is the best settings?? ie; sensitivity level..percentage level..and rpm level...
Powercommander recommends 90% sensitivity..15% fuel..10 rpm for street..
What is the best for track settings?? Oh wise ones..pls help!! hehe..
Old May 24, 2006 | 12:40 PM
fisherman's Avatar
Default RE: PC III Accelerator Pump
I'm using the accelerator pump on my bike. It is great for track but I hardly notice it when riding on the road. Most noticable out of slow corners, great for power wheelies in 2nd. Currently I've set mine up at 80% sens, 30% fuel and 20 rpm but I play with it from track to track
Old May 26, 2006 | 01:57 AM
im about to custom remap my PC III..do i remap it first den download the accelerator pump or remap it 2gather with the accelerator pump?? and why is the rpm starts frm 1 to 40 rpm only?? does it mean it boosts fuel for up to a max of 40 rpm only?? ie, at 7k rpm when it is activated..the boosts will last till 7040 rpm only??
Old May 26, 2006 | 07:34 AM
Seltorque's Avatar
I thought the 1000RR has some form of accelerator pump in the EFI. As I was advised not to install it.
Old May 26, 2006 | 10:01 AM
MgA_ODEN's Avatar
ORIGINAL: Seltorque
https://cbrforum.com/m_90606/tm.htm
Old May 26, 2006 | 10:42 AM
fisherman's Avatar
Installed mine after custom map was done. See http://www.powercommander.com/maps/i...t_ap_parts.pdf for details on how it works and how to set it up.
Old May 27, 2006 | 07:47 AM
Anubis's Avatar
I`m with fisherman on this, I turned it on and on the road it just wasted fuel for me. On track it makes alot more use, when you want a little extra push from the combustion. But even then I don`t use it on track tbh, only once and it wasn`t a significant enough increase for the fuel used.
Old May 27, 2006 | 09:28 AM
fisherman's Avatar
Anubis is right about it guzzling gas! Fortunately our fuel is still relatively cheap in comparison to the actual cost of bikes. We get ripped off on the bikes for example my 06 CBR 1000 RR cost me R110 000 which is about $17 000 US and GBP 9200. I pay R6.50 for a litre of 95 unleaded which is about $1 per litre and 1/2 a GB pound per litre.
Old May 30, 2006 | 03:34 AM
so wat do you guys recommend for me who uses the bike for daily commuting to work and who quite often enjoy bursting to top speed on the highway??...
Old May 30, 2006 | 09:05 AM
Seltorque's Avatar
Since it is a free upgrade. Stick it on and see if you like it or not. I am with the other guys. You will only burn more fuel and I know in Singapore you can't go that fast as them SG cops will lock you up and throw the keys away for sure
