Integrated tail lights?
Old Jun 13, 2007 | 05:03 PM
jeffrimerman's Avatar
Default Integrated tail lights?
I read alot of post bout different tail options. It seems like the simplest and cleanest would be to get the integrated tail light with built in blinkers and relocate the license plate with a separate piece from ebay all done for about $100. However, I wonder if the light missing from the plate will be illegal in CA, and I wonder if taking all the stuff off the stock exhaust might not look as good. Has anyone done a similar mod with the stock exhaust?
Old Jun 13, 2007 | 06:15 PM
tpgpz's Avatar
Default RE: Integrated tail lights?
I am sure that it would be illegal...I know it is in OH. So this is what I did. I started with the Comp Werkes eliminator and did not like the cheesy little lights they give you, so I bought the Clear Alternatives tail light and put that on. So all I am really using off of the Comp Werkes is the license bracket and the relocation of the light. More $$ than I needed to spend, but that is how it ended up. It looks really clean though, and I get a lot of compliments on it. Here is a pic for you. Not sure if it will have enough detail. Let me know...I can get you a better pic if you want.
Old Jun 13, 2007 | 06:28 PM
tpgpz's Avatar
Here is another pic...little closer...see if that helps at all
Old Jun 13, 2007 | 07:50 PM
That looks pretty sweet. I ordered one that has the plate light and has little blinkers attached to it also. Hopefully it will look good. I will post some pics when I put it on. I might still want to get the integrated blinkers one. Thanx tpgpz.
Old Jun 13, 2007 | 08:00 PM
unforgiven's Avatar
I did the Jardine Fender Eliminator, CA Integrated Tail light and use LED Tag bolts. It looks good. Not the brightest lights, but it's legal.
Old Jun 14, 2007 | 12:18 AM
menefreghista's Avatar
ORIGINAL: tpgpz
looks swell but ya need a G-Craft Type II brake reservoir to clean up the undertail
Old Jun 14, 2007 | 08:27 PM
tpgpz's Avatar
Where do you get those?
Old Jun 14, 2007 | 08:33 PM
ORIGINAL: tpgpz
http://www.superbikesupply.com/index...p;ItemsId=2037
rem to call 828-252-2280 for shipped price ... don't go by website rules of Min Advt Pricing
alternatives to stock are also made by Rizoma
http://www.pjsparts.com/catalog/prod...products_id=90
http://www.pjsparts.com/catalog/prod...roducts_id=173
Old Jun 14, 2007 | 10:46 PM
bboi's Avatar
ORIGINAL: menefreghista
ORIGINAL: tpgpz
How do those things mount?
Old Jun 15, 2007 | 08:27 AM
ORIGINAL: bboi
ORIGINAL: tpgpz
ya can't be serious
pump & drain the rear brake line first
unscrew and take off the stock connector (DO NOT lose the stock O-Ring washer 14.8 x 2.4)
put the new reservoir in with the stock O-Ring washer
refill and bleed the line ... takes less than 15 minutes if you have the right tools
Please keep a wet rag handy to wipe off any spilled brake fluid on plastic & metal components
p.s.
if Rizoma & G-Craft are too expensive for your budget, get for the 15cc plastic Brembo reservoir that can be hooked up to the stock tubing.
