-   1000 Modifications (https://cbrforum.com/forum/1000-modifications-42/)
-   -   How to install a slip on? (https://cbrforum.com/forum/1000-modifications-42/how-install-slip-56864/)
sweetdeal Jan 2, 2008 05:33 PM
I am installing my sato slipon and i was woundering if there was a how to thread anywhere here? My questions are basically about the exhaust cables, where, how, what not to do? this is my first undertail exhaust installation any tips?
baxsom Jan 2, 2008 05:41 PM
RE: How to install a slip on?
www.hooliganbiketech.net
look up the link for arata ti slip on
it walks you through everything
mihomie Jan 2, 2008 06:59 PM
what year bike?
did you buy the pipe used without instructions? ( like i did )
baxsom Jan 2, 2008 07:26 PM
04-07 is the same
the only difference is the location of the servo for the exhaust valve
yet another write up
http://www.hardracing.com/Exhaust%20Systems/Micron.htm
sweetdeal Jan 2, 2008 07:58 PM
yeah i have an 06 and i bought an 05 sato exhaust. It actually was a fairly easy install everything fell into place and brackets lined up pretty easily. just not sure about the servo and little things like side heat shield.
sweetdeal Jan 2, 2008 08:18 PM
yeah i just read both of those write ups but i dont know if how i removed the cables messed anything up i just loosened the nuts holding the cables and was able to pop them out of the holes and then tucked them up into the "trunk" by the battery box. let me know?
baxsom Jan 2, 2008 08:20 PM
get rid of the heat shield
both the AL one on top of the can as well as the AL one on the side of the bike
use Cool It brand heat tape between the can and the undertail
unhook the cables from the servo
on a new pipe the exhaust valve goes away anyway. servo for the 06/07 is under the seat in the same compartment as the trunk lock
sweetdeal Jan 2, 2008 09:06 PM
yeah i pulled off all of the heat shielding the whole can and midpipe are titanium do you think i will still need the cool it? As far as the cables go i wasn't sure that what i did may cause the check engine light?
baxsom Jan 2, 2008 11:02 PM
with ti you can take all the heat shielding off and be ok
with the cables they really need to come totally off. reason is, they are still attached to the servo. the servo will still turn moving the cables back and forth. they can get caught and lock up the servo messing up the servo motor. this will cause a check engine light. you must however leave the servo plugged in or you will definetly get a check engine light
sweetdeal Jan 3, 2008 04:57 AM
that is the answer i was looking for, so i can disconnect them from the servo (inside the key lock box as well) just dont mess with the servo inside the box. That makes sense. I was told to "just ziptie them out of the way"
thnx
yeah as far as the heat shield i wasn't sure if i was supposed to be able to put the side portion backon, it wont fit around the mid pipe anymore i have only seen one side pic of a Sato exhaust and it didnt have the side heat shield either,
anyone else have alot of left over screws? https://cbrforum.com/micons/m16.gif
haha. i am assuming they are all from the the old heat shieldand undertail but i seem to have a large pile. I have secured all the important structural things, (exhaust, seat brackets, trunk,ect) but i seem to see alot of empty holes that dont attach to anything.
