-   1000 Modifications (https://cbrforum.com/forum/1000-modifications-42/)
-   -   HIDs with 08 1000rr (https://cbrforum.com/forum/1000-modifications-42/hids-08-1000rr-138052/)
The__Rider May 13, 2012 08:30 PM
HIDs with 08 1000rr
Just ordered a set of HIDs from DDM Tuning for my 08 1000rr. I was looking at the bulb housing for the headlights and wondered where the wiring will exit to connect to the ballast from the bulb. There's a screw off cap that locks behind the bulb, so where will the wiring exit and hookup to the ballast that will be mounted somewhere on the frame/fairings?
If anyone can provide pictures that would be GREATLY appreciated! Thanks
The__Rider May 14, 2012 08:20 PM
uh. bump?
jeffjones May 14, 2012 08:22 PM
Not to sure without a pic but ddm has a lot of downloadable instructions.
You may need a step drill bit and drill a hole out of it to run the bulb through and use there included grommet to re-seal it.
