Hey guy's
Just got a 2012 1000rr ,has a 2 bro's pipe,what it's doing is like chugging at constant rpms,planning on getting after market filter,what's the best feul adder to get?too many to pick from,any input? Tx
Two Brother's suck! Dont waste money on aftermarket filter. If they let more air in, they're letting more dirt in. Bazzazz or PowerCommander because with those you can not only add fuel, you can subtract fuel also. You should also get the "timing retard eliminator" Bazzazz is Z-Bomb, DynoJet is the IRC. Or you could skip all that and just get your ECU Flashed by Dano's for $200, it does away with all factory restrictions. Smooths and optimizes the power curve and fuel ratio and no need to buy the Power Commander or Bazzazz. And you can still run aftermarket exhaust without being to lean.
Hey frank tx for the info,I have a cousin that lives around winchester value that does the ecm flashing,problem is I live in Myrtle Beach now,and haven't found any one that flashes ecms here.ones that I have contacted says buy a pc5 and come in and have it dyno'd.sounds like they're trying to just get deeper into my pockets.lol I'm going to do a little more research on the flash.im sure someone with in 2 hours of here can do it.sounds like the ecm flashing is the way to go
..I'll get back when I find someone.tx again frank |
Winchester va
You should go visit your cousin on a weekend when theres racing or trackdays at Summit Point Motorsports Park. It just a belch & a holler over the hill from Winchester. To get the bike almost perfect a flashed ecu and the Power Commander 5 or Bazzazz would be ideal but its not necessary, just a flash will do.
1 Attachment(s)
Actually my cuz lives in Martinsburg,he does track day's there,his buddy does the flashing,he's in Winchester.id take to him but that's like 9 hours from me,going to look some more today around here.i had an 05 and a 07 that I just put power commanders on that ran fine.my cuz says go with the flash.hes got a gxr 1000 flashed,runs perfect.
Originally Posted by coalminer frank
(Post 1298422)
The U.S. bike has government restriction, either noise or pollution. By installing the Z-Bomb or Dynojet IRC, it tricks it into being unrestricted but........its will then be a little lean at full throttle at 10,500 rpms, so now you need to add fuel back into it and the only was to do that is with the PowerCommander 5 or Bazzaz ZiFi. Or you can skip all that and just have your ecu flashed. A flash will remove the restrictions and add the fuel, and a few other things if you want. All this is referencing 08 and up cbr 1000rr. Not 07 and before, that I know of. I dont study to much on 07 and before since I dont have one of those.
A flashed ECU is a hacked and reprogrammed ECU. So, as to whether or not you can get yours done depends on if someone has made a program for it or not.
Looks like tgere are companies that flash 04-07 1000rrs https://ecunleashed.com/honda-cbr600...mance-reflash/ |
Originally Posted by Conrice
(Post 1298494)
