headlights
Is there any whay to get both headlights to shine on low and hi beam on 2006 1000rr?
RE: headlights
What i did is i lowered my high beam light to equal my main light.You turn the bolt on the top right side of the back of the high beam housing unit. this will lower the high beam. it is a goodidea to face your bike at a wall about 10 feet away so you can see the high beam moving and you can know when to stop. Then you just leave the switch on for your high beam 24/7 and if the light on the dash bothers you either just deal with it or cover it with tape. This is the easiest way to do it...it took me less than aminute to line up my lights. Hope this helps.
