galfer brake line set up question.
i have a 07 cbr1krr. Looking into getting galfer stainless braided lines front and back.. i was reading some where that you can route the front lines into a "race setup" where its two seperate lines from the master cyl. and one line goes to each caliper up front... Does the kit from galfer have the neccesary components to do this set up? or does the kit only have the proper components to mimick the stock routing?
And is there a kit out there that will alow for a double line set up? i just was thinking about this option because it cleans up the look a little bit. not as much line needed either. thanks. Joe |
you should call a shop selling Galfers and ask... i was just shopping for Galfers for my 07, and they all appear to be a 2 line set up...
when i got mine they were a 2 line set up, 4 years ago though
just a larger banjo bolt to accomedate the two lines at the master..saw this kit at J&P cycles awile ago...
Originally Posted by 07ceeberthousand
(Post 886444)
you need a double banjo bolt for the master cylinder. i did this set up and love it
