fully adjustable lowering links
do u suggest those ones baxsom? i am thinkin of doing it also and how hard is it to do it? want to lower it so my girl can ride it. i heard you have to adjust your headlights when you lower it also? thanks for the info. not tryin to thread jack btw. hehe
i dont really like lowering links myself
they mess with the suspension geometry. you have to lower the forks in the triples to compensate. a good suspension tuner can make it like stock again. i just remembered seeing them on ebay and thought i would help
i saw others that was an actual bolt that adjusted up and down kinsa like the bikes shift rod but cant remember where they were.
BE CAREFUL about lowering the bike... I lowered mine and ran into problems of the bike actually bottoming out and the tire rubbing on the undertail... I had the hotbodies undertail and you could see the tire marks from where it bottomed out. I recommend stiffening up your suspension all the way if you plan to have a rider as well as yourself, but be warned... I only went down one inch and ran into problems.... otherwise it looks Looks and feels great
