Flapper mod...
Old Feb 9, 2008 | 03:26 AM
Volksdragg's Avatar
Default Flapper mod...
Hi, I just joined this site and was wondering what is a flapper mod? Also how do you folks modify the air box and is there any documentation of improvements? Thanks for your help!
Old Feb 9, 2008 | 08:47 AM
Onarom's Avatar
Default RE: Flapper mod...
Here is a description and how-to for the flapper valve:
http://www.rogueracing.org
Old Feb 9, 2008 | 03:43 PM
Volksdragg's Avatar
Thanks for the link!
Old Feb 11, 2008 | 09:07 PM
goracer's Avatar
You will want to do the exhaust flapper as well or I don't see the point. You gain mid range HP but not overall HP. I think the screw thing is stupid as it does not take much more effort to remove the pastic and simply unplug the solenoid and zip tie that. I removed everything and caped off the nipple on the engine block.
Enlarging is removing the deviders and fiberglassing the holes from the small flappers you see on the sides. I supoose you could try speed tape isntead of fiberglass. I opted to keep the deviders for the side chambers with the small flappers and I glued the small flapper doors to cover the holes and opened the front. Don't worry about this untill you have upgraded the filters, exhaust and have a PCIII to tune.
Old Mar 6, 2008 | 06:39 PM
2Loctite's Avatar
I have not yet seen a dyno where ONLY the flapper mod was done and there was a HP gain.
Because it doesn't exist.
Old Mar 6, 2008 | 06:43 PM
2Loctite's Avatar
http://www.speedzilla.com/forums/rc5...tml#post442314
Read the bottom of the post.
Old Mar 6, 2008 | 09:05 PM
openclasspro's Avatar
ORIGINAL: 2Loctite
it does exist -member spreedy from 1000rr.net dynoed it
Old Mar 7, 2008 | 09:22 AM
2Loctite's Avatar
Link?
I showed you mine.
Old Mar 15, 2008 | 10:42 AM
KILLER EX's Avatar
is there a flapper on the 06 600rr?
Old Mar 15, 2008 | 02:35 PM
MgA_ODEN's Avatar
ORIGINAL: 2Loctite
Idiot.
http://www.hooliganbiketech.net/hond...flappermod.htm
