Exhaust valve Question
Old 03-17-2006 | 06:59 AM
Anubis's Avatar
Default RE: Exhaust valve Question
Take them all the way out Rog, the cables will get caught up. If you disconect them at the valve end the servo still works so you`ll have the cables moving to and fro under your tank.
If your gonna disconnect the cables anyway do it at both ends its dead easy. One thing you do need to know though is:
Mark the servo position before you start any work so you can return it to its original starting position or you`ll get the F1 light come on.
The cables are just like bicycle brake cables with the little thing on the end, you may need to raise your tank so you can see to get them out but it`s literally 10 mins mate.
Take ya seat off,
Undo the bolts at the base of the tank cover,
undo the bolts on the covers at the front of the tank cover and remove,
undo the 2 bolts on the tank cover itself at the front,
lift it off,
theres a bolt either side midway on the tank, if you undo these then the petrol tank can be hinged backwards so you can see where your fiddlin to remove the cables.
Old 04-23-2006 | 09:56 PM
repsol rob's Avatar
i heard to remove the exhaust valve welding is involved and you should just buy the full system. by removing the cables are you sure that the valve is stuck open?
if you could provide detailed instructions in removal that would be great. !![8D]
Old 04-24-2006 | 11:10 AM
Anubis's Avatar
yep, i`m sure.. i`ve done it to my UK bike, as far as any other countries spec i couldn`t say for definate but i`d say yeah the valves the same and is open as standard with the engine off.
Old 05-03-2006 | 06:09 PM
fisherman's Avatar
OK Anubis, so I read this too late. Fitted the full Arata Ti syatem last night and completely removed the lot including the servo and now have the Fi light permanetly on. Replaced the servo but no good, light still on. Now I did not mark the servo position but can't seem to adjust it because whenever I power up it returns to the same position from which it can't be manipulated. Any ideas??
Old 05-03-2006 | 06:38 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Put the servo back on!!!! Just disconnect the cables. It'd be nice if there was a plug in that'd make the bike still think the servo's there but so far I haven't seen one.
So to reiterate -- don't take the servo out -- you'll get an FI light. Just remove the cables and everything will be fine
Old 05-04-2006 | 05:55 AM
fisherman's Avatar
Thanks chainstretcher, I have done that but the light stays on. Anubis was indicating that the position of the servo needed to be marked and returned to same position. This I did not do. Tried changing the servo position but it always returns to the same position when I power up.
Old 05-11-2006 | 09:06 PM
Repsol1's Avatar
Try moving the servo when the bike is turned off. You will have to play with it in order to find the original setting.
Old 05-12-2006 | 11:05 AM
fisherman's Avatar
Yep, I tried that, moved it slightly in each direction but everytime I turn on the ignition, it snaps back to the position I started from [:@]
Old 05-13-2006 | 02:12 PM
repsol rob's Avatar
does anyone have complete instructions on how to remove the whole thing....i was told by a mech. that removeal of the exhaust valve would require welding?? is this true.
Old 05-14-2006 | 05:16 PM
roxy_33's Avatar
Thats way too much work to disable the exhaust valve. Just pull out the cables dude...... I went a step further while reworking my stock can and took the valve "door" out of the inside of the pipe when I had it off. Two small bolts and it was gone.
Shipleymanx
10-26-2013 01:30 PM
K20what
03-26-2009 04:07 PM
palmer929
09-06-2008 05:42 PM
frostyrider
04-20-2007 11:48 PM
reevesna
07-01-2005 09:14 AM
Quick Reply: Exhaust valve Question
