exhaust, pc3, what else?
so i got the two bros pipe (2007 fireblade btw) is there a head pipe? someone told me that a jardine or something for an '05 will fit? im not 100% sure so i figured i would ask here and see what comes up.
i got PCIII, and air filter set up. now im wondering what to do next as far as power mods go, i can get 110 oct at the pump so with the ignition module i should be abel to advance the timing enough to get the benefit of the higher oct.? Is there any aftermarket parts such as cams, or throttle bodies for our bikes? just trying to figure out where i can squeeze more juice or is the exhaust, air filter, pc3 and ignition pretty much where aftermarket really ends? then if u want to add nitrous which im coincedering maybe by july. any who... let me know whats up! |
have you done any dyno runs before and after?
im in the same boat as you... what next? and i had a custom map..
