Competition Werks FE & Jardine RT-One Carbon
Good Evening All,
I am new to this site and have a quick question that I am hoping someone can assist with. I currently have the Competition Werks FE and have ordered the Jardine RT-One Dual Outlet Carbon Exhaust. I have heard that I will no longer be able to use the FE with this exhaust. From all the pictures I have seen, I do not see why I would no longer be able to use the FE. Can anyone shed a little light on this for me; I would greatly appreciate it.
Cheers,
Sprout
Cheers,
Sprout
RE: Competition Werks FE & Jardine RT-One Carbon
I have this exact set up on mine. The Fe works fine and looks sick too. Dont worry about. Oh and just for a little for-warning, If you are having problems with clamp on the exhaust that bolts to the under body, just go buy a longer bolt and it will work fine.
Hey Hulk,
I installed the RT-One Exhaust today and it went very smooth. The attachment of the can was not an issue at all, the bolt was plenty long. However, I do have a question regarding the clamp connecting the s-pipe to the head pipe. I noticed the nut went pretty far down the bolt as I was tightening it down. Did your experience the same thing? I was afraid to keep tightening it for fear the bolt would snap. I started the bike in order to check for exhaust leaks at the clamp, andnoticed a little exhaust leak so I tightened it until the leak wasapparently gone. Lastly, did you reinstall the heat shield as indicated in the directions? I noticed a lot of people do not. Thanks again for the assistance.
Sprout
Sprout
Once I got the stock exhaust removed I still had a metal ring on the head tube which I left on. It looked like it was a welded in place. The Jardine S-pipe fit over the head tube all the way down to the ring I am talking about. That is where I put the clamp on. Can you take a pic of your clamp and shoot it too me?
Thanks,
Sprout
Thanks,
Sprout
I have installed jardine rt -one exhaust on my 07 1000 and i have noticed that the bike is sluggish on take off from a stop light it has poor throttle response. I have installed power commander with the jardine map and it didnt help much has any one else had this problem
This set up is causing some sluggishness out of the whole for me too. I am working on some custom maps to see if I can help this out any. With that said the bike is extremely responsive from 3500rpm and on so I am not too worried about the out of the whole response.
