Bazzaz tuning for top end - Rich or Lean
I have a 2011 CBR1000rr accompanied with the
Bazzaz Z-Fi, Z-Afm, Z-bomb Two Brothers exhaust Bmc air filter I've been tuning it recently and it rides like a banshee through the midrange, which is already characteristic of the CBR, but I'm trying to increase the top end. The latest tune is set to 13.0, which felt better than 13.2, and I'm about to try it at 12.8. Is anyone familiar with the air to fuel ratio on Hondas, especially on the top end? If anyone has some good experience with the positive or negative consequences of rich or lean mixtures as it relates to Hondas, and more specifically (2008-2011 cbr1000rr's), it would be greatly appreciated I'm hearing that it might be best to lean it out on the top end, but I'm not sure. |
I just replied to u in the dyno thread, didn't know u had ur own thread going.
simplified response: u want to go lean, always, to a point just before detonation. That is where u achieve the most power. U r going DOWN in A/F Ratios, therefore making it richer and increasing fuel, typically resulting in a loss of power. You A/F Ratios should be between 13.5-14.2 throughout the rpm range. |
Originally Posted by goodkookin
(Post 1124138)
I have a 2011 CBR1000rr...
The latest tune is set to 13.0, which felt better than 13.2, and I'm about to try it at 12.8. Also, you posted this in the 1000 Modifications area. There's also a CBR 1000RR section. :) |
