Air injection control valve
Hi, have anyone disabled the Air injection control valve? And if so, will it result in miss codes?
http://www.hondaoriginalparts.com/ho...2&block_03=533 Richard |
why would you do this?
You can't dyno tune with the PAIR system in place, the extra air in the exhaust stream makes the analyzer think the bike's running way lean. Removing the PAIR plumbing also makes accessing the plugs a lot easier, and on my Blackbird also allows the valve cover to be removed a lot easier if necessary.
and on my Blackbird also allows the valve cover to be removed a lot easier if necessary. |
