1/6 turn throttle?
RE: 1/4 turn throttle?
Your bike has a 1/4 turn throttle , are you looking for a 1/6 turn throttle ?
I'm not sure if it will work on the '06 , give them a call.
http://www.kyleusa.com/catalog/hrc_q...05_4724651.htm
do it yourself with a large zip tie trim it and use smal screws to to attache it to your throttle tube seen it done on an r1 you may have to adjust measurments
go to borgs links look in servie sections
http://borg20012.tripod.com/service_sectiong.htm no.7
Can't see how it could be dangerous ..... All you're doing is building up the groove that the cable lies in to shorten the stroke. If by some freak accident the cable tie disintegrates you are back to where you started. If it jams the cable, pull in the clutch and hit the kill switch. I've dropped a fair amount of cash into my bike as well but that's no reason to overpay for a gadget. I've built 2 Big Bear Custom choppers with my own hands so I know what not to take chances on because I ride them too and have no ambition to do myself any injury. All the mods to my bike are by my own hand.
Call me a silly goose but I measured mine ('04 1kRR) and mine is a true 1/5th turn. Haven't done a thing to it either. Even if it were only a 1/4 turn if you grip it correctly from the beginning then you don't run out of hand before you run out of throttle. Just takes getting into the habit.
