07 GSXR Mirror With Integrated Turn Signals Retrofit
#31
#32
Wow I haven't been on this forum in forever. I did not remove the bosses. I just enlarged the holes as the bolt pattern on the gsxr mirros is different. I considered swapping mounting bases between the mirrors but it is not doable. The wires travel through the mirrow body and through the hollow stalk, and then through a hole I drilled between the two mounting bolts. They are wired to the stock turn signal connectors. I extended the wires and swapped connectors so they plug right in. You can see it in the pics. BTW I could not see an easy way to run them as running lights as the stock signals. The stock signals use a dual fillament bulb and the gsxr mirrors use a single. I don't see a need as the bike already has a running light above the headlight. I guess if you wanted you could install some flush mounts and run them as running lights in combination with the singal mirrors.
#33
silver93t
How-To: Mechanical
06-19-2007 11:10 PM
