'06 1000RR Stock Map
Old 07-18-2007, 07:49 PM
brendan1026's Avatar
Registered Users
Default RE: '06 1000RR Stock Map
ORIGINAL:
brendan1026 I contacted Dan Kyle Racing about a PCIII map for an '06 1000RR running a stock pipe. I was informed they DO NOT, I repeat DO NOT, have a map for the 2006 1000RR and a stock pipe. They said they could supply the PCIII module with the DynoJet map that works with a stock pipe.
Well, I have no way of knowing if Dan Kyle made the map himself or not, but it's posted in the PCIII Maps section of this message board and it's called Dan Kyle Map. I compaired it to the stock PCIII map and it is not the same at all. I suggest giving it a tryif your running the stock exhaust.
Old 07-19-2007, 11:17 AM
mihomie's Avatar
brendan can you posta link where you pulled the map.
Old 07-19-2007, 12:27 PM
Registered Users
Here you go. https://cbrforum.com/m_33384/tm.htm
blkmrkt_lung
11-25-2006 02:12 PM
A_93_900RRER
03-24-2005 07:18 PM
Quick Reply: '06 1000RR Stock Map
