'04-'05 subframe
A ton of things could change the part number. Different material, Even something as simple as a washer or different style bushing can change the entire part number. even just a body style change, no matter where on the bike the change too place. As you probably noticed, the tail section between 04-07 are the same. The 04-07 headlights are the same too, but they changed part numbers between 05 and 06.
As far as I know, the subframes are basically the same and should work 04-07.
