just another wheelie question
Hey guys,
im kinda new to the bike scene, only been riding for about a season. I'm really comfortable with my bike(it an f2), and think I'm ready to take the motorcycle experience to the next level. I've been trying to do a wheelie for awhile now, but can't seem to get the front up.
My wheelie entry rpm is around 4k and I think when I release the clutch its somewhere around 6k. I as just wondering if this was too low? And is there just a ball park rpm rage I should be aiming for?
I know every machine will be different, I'm just looking for a range that I can play around with to see where mine needs to be. Thanks for any help or info!!!
Oh and i do have a bigger sprocket in the rear.
Don't think about the rpms having to be at a certain rate as that will have you looking down and not concentrating on your wheelie.
rpm speed does not really matter when clutching up.
It comes down to how much you have twisted your throttle.
If you don't stay on the gas the rpm's will drop as soon as you release the clutch.
Just start low and keep twisting the throttle more and more until the front pops up, then you can start learning to stay on the throttle to keep the front up.
Ok, ill try more tonight just playing with the throttle. I'm doing this in 1st gear btw at around 15-20 mph sometimes in second. I'm trying to learn in 1st gear first just to get used to the feeling, then ill go to second. Now I've herd the stand up on the the rear peg( with the left, and covering brake with the right) would be a good way to learn how to handle the clutch and get a feeling for it. Is this really a good idea?
Are you used to riding like that? Then why throw another variable in.
That is more of a stance for low speed parking lot wheelies.
I also have an f2 man, and trust me its not that easy to pop a wheelie. First of all I can only do it in 1st gear for some reason, but I cant stay on the throttle and balancing it, so nose always goes down.
If this is gonna be a stunt bike just swap the sprockets and you will make your life alot easier.
There was a video posted the other day of a guy doing a 2nd gear wheelie down the highway on one.
Also a buddy can do wheelies all day long on his 30HP 250.
