Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
balance point at high RPMs
Old 02-03-2013, 03:08 AM
redbaron1728's Avatar
Thumbs up balance point at high RPMs
OK so i ride a 2000 cbr 600 f4 as my stunter. I can't say my tooth size because I forgot the actual number, but I do know it equals out to half a tooth up in the rear. Basically stock. Its like front down one and rear down one or two or some weird **** ( all they had in stock when my chain broke and was in an emergency to have a new kit put on).
So there's a little knowledge on my bike. I'm currently learning how to consistantly place my Nike into balance point via rear brake and throttle. I have successfully gotten out of the squirrel habit of bouncing up and down because of no rear brake adjustment! Ha I know I'm only a beginner but I'm very proud of getting out of that habit. Here's my problem, no matter how much I slow my bike down in balance point, I'm still at at least 9500-13000 RPMs. My question is, is it possible to reduce that with a better sprocket ratio? I.E. -1+2? Does the different sprocket set up only reduce speed of wheelie or will it reduce both speed and RPM or just the RPM?
Old 02-03-2013, 01:38 PM
jeffjones's Avatar
If you put -1/+2 on you will be at a higher RPM at the same speed.
My guess is your power wheeliing because of how high your rpm's are.
Try clutching up at a lower rpm and you can pop it up to BP around 5k rpm and then ride from there.
If you are clucthing up, do so at a lower rpm or a higher gear.
Ls1Mx5
10-03-2014 08:26 AM
Karmakazi
10-04-2009 09:20 PM
xRej3cTx
04-04-2008 01:31 PM
brandonrs5
08-15-2007 09:44 PM
Turboedsupe
05-11-2006 12:12 AM
Quick Reply: balance point at high RPMs
