f4i fighter
#21
As far as the shock - make sure the angle put on the swingarm from the increased height won't wear a gouge into the swingarm... Happened to me when I put an F4 shock on an F3[/QUOTE]
i'll double check that..
#22
i think this works better for duct covers, and forms an effective screen. gave my tank a ****ty paint job with not much prep too
20160717_193122 by Steve, on Flickr
20160717_193131 by Steve, on Flickr
#23
more paint (just the top part of the frame)
20160721_133619 by Steve, on Flickr
20160721_133611 by Steve, on Flickr
#25
#26
20160723_204121 by Steve, on Flickr
20160723_204139 by Steve, on Flickr
20160723_204131 by Steve, on Flickr
20160723_204231 by Steve, on Flickr
#27
#28
definitely taken a break from body work, working on the engine some more.. figure even though its a street fighter, might as well make it faster.
went nuts with electronics, power commander 5 with autotune wideband trimming n-alpha vs gear selection.
im glad i got that going, though, my custom exhaust and modified airbox threw the stock map out to lunch. in cruising areas i yanked a ton of fuel and the bike doesn't seem to mind at all. i really feel it hits peak power from 9000rpm+ at 13.5:1, although even in first gear, it's scary to test, so if i ever get the chance to dyno it on the cheap, i will. it's definitely been a bit of a chore to get the tune dialed in, im really used to tuning cars, and this thing is really picky..
next project is relocate key switch away from handlebars, then move gauge to top of triple, then add a spotlight style LED (current one is flood) for high beam and try to get them closer to the frame to tighten it up a bit. i might get lazy and just add the second light though. not sure.
#30
im pretty sure my *** rubbing on the tire would wake me back up if i fell off.
that is actually a bit of a problem.
i'd usually pin myself against the rear of the seat under hard accelleration to reduce input on the bars
im adjusting to it
the added input of having less bike to work with definitely begs for a steering damper or something. i hope to come up with something on the cheap, maybe an HRC style one, ever seen those? runs from the front fairing stay to the upper fork tube, so its hanging right out the front of the bike. might look cool having one exposed like that
im adjusting to it
