Aftermarket Discuss aftermarket upgrades to your CBR here.
IAT sensor upgrade?/k&n filter
Old Feb 26, 2005 | 08:14 PM
motorbuff929rr's Avatar
Default IAT sensor upgrade?/k&n filter
has anyone tried out one of these IAT performance chip installs, thinking about purchasing one, they make them to use for almost anything i m thinking they ll probably help a little bit, also i put a k&n air filter in my bike, thinking it probably helps but have been told buy a few people that the stock actually works better any thoughts?
Old Feb 27, 2005 | 08:36 PM
L8X's Avatar
L8X
Default RE: IAT sensor upgrade?/k&n filter
whats a performance chip? got a website?
Old Mar 5, 2005 | 01:09 AM
it's not much of a chip, well it tells your ecu that your getting cold air which in turn will add fuel to compensate and advance the timing, which should give u a faster response at the throttle, found on ebay, not exactly sure how well it works, need to locate the sensor first, but will update a response once i find out
Old Mar 5, 2005 | 12:16 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Don't buy that 'chip'. There's absolutely nothing to be gained by richening up things when the bike is warm unless you like pushing the bastard or waiting an hour til it cools[8D] Oh, and some really cool backfires when decelling. Buy a power commander and install a map for your mods or better yet have a personal dyno map created for your bike. On some bikes (Busa's in particular) the IAT was a little too close to the engine and therefore moving it an inch away made the bike run better. But those issues seem to be rare and only involve moving the stock IAT not installing something different.
As far as the K&N filters, I've been hearing the same stuff - that the new stock filters flow just as well. A big advantage to the K&N is that once you buy it, it's there forever. Just clean it and lightly re-oil and that bad boy's good as new.
Old Mar 11, 2005 | 01:45 PM
1000RR's Avatar
K&N on a my 2000 F4 (M4 pipe) required a
Jet-kit / Carb Sync to work right.
Bike worked great with stock filter, K&N caused big problems
after about 10,000rpm. Switched back to stock, all was good.
Added Jetkit/carbsync/reinstall K&N and she ran better then ever.
On stock bike, K&N's are crap.
Old Jul 20, 2005 | 12:44 PM
littleninjagirl's Avatar
On stock bikes I agree that K&N's dont work well.
Old Jul 26, 2005 | 08:12 AM
mmookey's Avatar
BMC is a good filter. Check out what Rogue Racing has to say about them: http://www.rogueracing.org/bmc.htm
YvenelC
Jan 20, 2013 12:47 AM
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
sco7tys
Mar 27, 2008 06:41 PM
usndocjaysin
Sep 21, 2007 10:18 AM
