  #51
Old 08-19-2009, 11:21 PM
Jerzdan's Avatar
Jerzdan Jerzdan is offline
Send a message via AIM to Jerzdan
If they are new relays i doubt they are defective. It probably your wiring somewhere. When i screwed mine up i sent a private message to both the guy who started the post as well as the guy who posted the wiring diagram and they helped me out so it might be worth a try. You might have to solder in some diodes into your wiring but i dont know for sure so like i said, the guy who started the post helped me out so give him a shout.
  #52
Old 08-22-2009, 10:40 PM
Sparkyf2 Sparkyf2 is offline
So I did this to my 92 F2, no luck. None of my turn signals will work. I have checked the wiring and it's all good, i've checked my bar switch and it's good, I think the flasher relay might be bad. Also on my right side brake light works now, I think it's cause the relay I used is bad or something. The relay for the right side with click when I hit the turn signal but the one for the left side won't. Not sure what to do here, any ideas?
  #53
Old 09-20-2009, 12:28 PM
lxtasy lxtasy is offline
Ok I did this mod last night and I am VERY DISAPOINTED.Dont get me wrong, the mod itself is a great idea and worked great but the thing is that on my 98 900RR there isnt a divider in between the lights.So when I turn my signal on it bleeds over into the other light and looks like crap.
I was thinking about pulling my light apart and adding a divider but I am like so disgusted that I am going to pull all the wiring back apart and just get some different signals for the rear.
Dont get me wrong, its a great mod but just make sure you have a divider in between the lights or it will look like crap when you have a signal on and then hit the brakes.
Thanks,
Chris
  #54
Old 10-02-2009, 03:13 PM
crazycanasian crazycanasian is offline
I'm so close to finishing! Can someone help me out?
The only thing I cannot seem to get working is the left brake light. It pulses for the signal. But nothing for the brakes. I double checked the connection. Any other ideas?
  #55
Old 10-03-2009, 10:01 AM
redzintimidator's Avatar
redzintimidator redzintimidator is offline
Send a message via AIM to redzintimidator
is your relay cycling off once you turn the signal off? Test the signal from the front of the bike for the LEFT running light. You need to go from the front left of the bike, all the way around to the back, you cant use the right side running light signal. This is my guess... because it sounds like the relay is staying in the NC position and not activating when your turn signal is off.
2002 CBR F4i
Jardine RT-one Titanium High Mount
Homemade integrated Tail
http://www.cbrforum.com/m_720094/tm.htm
Hot bodies Flush Mounts
2-to-3 wire signal conversion
http://cbrforum.com/forum/showthread.php?t=84998
Slim Ballast HIDs
PimpBike Undertail
Vortex Frame Sliders
Tinted DB Windscreen
Armed Guard 200P Alarm System
  #56
Old 10-06-2009, 01:45 AM
It was a combination of bad stock wires and some bad connections! Everything is working and awesome! PS. I used a blue lid of a tupperware container to make the divide between the two lights. Worked great!
02, 954rr, bulb, cbr, conecction, f2, f4i, find, front, integrated, light, make, signal, tail, turn, wires, wiring
