Old 01-21-2009, 08:40 AM
utter05's Avatar
utter05 utter05 is offline
March 2009 ROTM
Send a message via MSN to utter05
Default RE: Integrated Tail ....Make one yourself for $12
I'm now angry, i just bought a integrated tailight for 80 and now i see this.
i never even thought about wiring up relays. Crap [:@]
1997 CBR 600 F3
Dynojet Stage 1
K&N Filter
Moto GP Shorty Exhaust
Flush Mount Signals
Integrated Tail
Harris "CBR" Grips
"If your not living for something,
then your dying for nothing"
Old 01-24-2009, 03:24 AM
aj_jensen73 aj_jensen73 is offline
ok im over my head with this one, I am on step 3 where in you instructions i need to cut the green/yellow wire on the bulb side but due to an accident this bike does not have the right colored wires and I am not sure which bike this tailight is off so i cant look up the wiring schemadic, the 3 wires coming out of the tail light are Black. Black/yellow. Black/white so i am not sure on which ones are for what. I am on hold on this project until I can figure that out. and no the tailight was not installed so i wasn't able to just look to see which ones matched up with what colours. I guess ill see how this project works out but it is a great write up its just me not knowing everything about electrical.
hoping someone is able to help me identify the different colours on the tailight. thanx everyone
Craig Jensen
aj_jensen73@hotmail.com
Two wheels equals one love!
Old 02-02-2009, 06:33 PM
redzintimidator's Avatar
redzintimidator redzintimidator is offline
Send a message via AIM to redzintimidator
the green/yellow wire controls the bright filament in the bulb. if you look at the diagram of the bulbs on page one, you will see it goes G/Y, G, and Bl/Br. Now i am assuming the pin order is the same with your bulbs. Im about 90% certain your solid black is the ground, ie, my Green wire. The next ones im not sure about.I would think that your black yellow is running light(my Bl/Br) and your black white is the brake filament(my G/Y).
Turn on your bike, cut the black white one, turn on your brakes, if that light no longer turns bright then thats the right one. if it still gets bright and the running light doesn't work then its back-ass-wards.
2002 CBR F4i
Jardine RT-one Titanium High Mount
Homemade integrated Tail
http://www.cbrforum.com/m_720094/tm.htm
Hot bodies Flush Mounts
2-to-3 wire signal conversion
http://cbrforum.com/forum/showthread.php?t=84998
Slim Ballast HIDs
PimpBike Undertail
Vortex Frame Sliders
Tinted DB Windscreen
Armed Guard 200P Alarm System
Old 02-13-2009, 03:08 PM
chiefF3 chiefF3 is offline
u can always ghetto rig also.. take a small bevel and make a hole in the back of your tailight housing and insert your current turn signals into those compartments.
that is why my friends did on his bike nad it work OK
P.S. This is what the alphabet would look like if Q and R were deleted!
Old 02-13-2009, 03:11 PM
ghetto riggin is possible...but this is cool...lol ;-p
2002 CBR F4i
Slim Ballast HIDs
PimpBike Undertail
Old 02-26-2009, 12:25 AM
Hangfire's Avatar
Hangfire Hangfire is offline
Theres a somewhat simpler way to do this using 2 standard SPDT automotive relays and some crimp-on female tab connectors. Using the left side as an example, tap a wire into the left front running light and run it to the 85 post on one of the relays then ground the 86 post. run the brake bright wire into the 87 post, the left rear blinker wire to the 87a post and wire the 30 post directly to the brake bright wire going into the brake light. Done, now repeat those steps on the right side, using the right sides blinker and running light wires of course.
When your turn the ignition on it toggles the relay to pass current from 87 to 30, which means that sides brake light works. When the blinker for that side is engaged the running light goes out and the relay defaults to it normal state, breaking the connection between 87 and 30 and connecting 87a and 30, letting the blinker control that sides bright brake instead, only the relay for the side thats blinking is affected so the other sides brakes works normally, one sides brakes are always toggled on no matter what.
This just uses standard automotive SPDT relays and a few crimp on female tab connectors to connect to the relays, it's actually pretty close to the same thing that Mitch has going on in his above post but done with commonly available relays. No soldering involved, just a few crimps. After working as a tech I really don't trust solder joints or wire twists much, seen alot of solder joints break and twists are, well, twists. A good crimper using non-insulated crimpon connectors and buttsplices then covered with some decent heat shrink tubing seems to do the trick for me. If you want to be fancy you can even buy the relay plug that connects to the relay and just wire all your connections into it, to each their own.
Anyways, I'll make a diagram and upload one in a few, it's really simple tho, the numbers I listed above are all stamped in the plastic on the relays next to all the posts.
Rez and Mitch's methods are great too, just all about whatever you have available to you to do it.
Old 02-26-2009, 02:20 AM
Hangfire's Avatar
Just make the red connections.
Old 02-26-2009, 01:21 PM
Lamar Vannoy's Avatar
Lamar Vannoy Lamar Vannoy is offline
That would be simpler since you wouldn't have solder but I think you'd need to swap you g/y and o inputs since the front running light cuts the power when the turn signal is on...
2003 F4i
Leo Vince C/F High Mount
Yoshimura Header
PC IIIr
Factory Pro Evo Shift Star
BMC Filter
C/F Intake Covers
C/F Tank Pad and Gas Cap
Red Gauge LEDs
Undertail Vortex Frame Sliders
Hotbodies Flush mounts
6000k HID w/ Delay Relay
Old 02-26-2009, 01:35 PM
goodwork hangfire! this can be done many ways. i agree with lamar, you will need to swap your NC and NO pins on the relay
2002 CBR F4i
Slim Ballast HIDs
PimpBike Undertail
Old 02-27-2009, 04:24 PM
Juddelicious's Avatar
Juddelicious Juddelicious is offline
Just did mine with the Automotive SPDT Relays, works slick, thx everybody. Used Napa AR143 relay BTW
97 Honda CBR 600
05 Honda Foreman ES
99 Chevy ZR2 Blazer
99 Chevy Silverado
02, 954rr, bulb, cbr, conecction, f2, f4i, find, front, integrated, light, make, signal, tail, turn, wires, wiring
