Help!! 07 1KR Won't Start
Old Nov 24, 2008 | 06:59 PM
hemigoat2003's Avatar
Default Help!! 07 1KR Won't Start
Hey Guys. I just replaced some fairings on my 07 1000rr. I also replaced my clutch cover. Now my bike won't start! It will simply crank the starter, but the engine won't fire. I tried toggling the engine kill switch back and forth, as well as cycling the key back and forth a few times, but to no avail.
Any ideas??
Old Nov 24, 2008 | 07:59 PM
justasquid's Avatar
Default RE: Help!! 07 1KR Won't Start
when you turn the key on, can you hear the fuel pump prime.? You can usually hear it the same time the tach is cycling.
If not. Is your bank angle sensor hooked up? Its the sensor that is mounted to your headlight. If its not hooked up, it will not allow the pump to kick on.
Old Nov 24, 2008 | 08:08 PM
HAVOC's Avatar
^^ also if you did hook it up but mounted it upside down that will make it think your bike is flipped over :P ... probably what you did , its very common mistake
Old Nov 24, 2008 | 09:18 PM
I assume the bank angle sensor is the one that mounts inbetween the headlights with 2 nuts? Perhaps i did mount it upside down. Is there a reset procedure for it once it is re-positioned, or will it work again when i re-position it?
THanks for the help.
Old Nov 24, 2008 | 09:34 PM
HAVOC's Avatar
yes just flip it over.. no reset it should fire right up , but it may take a few tries since youve tried to start it so much already
Old Nov 24, 2008 | 09:48 PM
Thats what it was. Flipped er over, and she fired right up. Thanks guys, i owe you a cold one.
Old Nov 24, 2008 | 09:53 PM
HAVOC's Avatar
just ride smart out there .. last thing i need is the important people in your life blamming us for helping you get the "death machine" fixed haha ... just remember pay it forward
Old Nov 24, 2008 | 10:01 PM
Hoshino's Avatar
ORIGINAL: hemigoat2003
As a new guy, I like to honor those that came before me. As a result of that, I will take the burden of the cold one. PM me for my address.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
