Does this idle make sense?
Old May 27, 2008 | 11:19 AM
Goose Rider's Avatar
Default Does this idle make sense?
Start the bike cold and it goes into it's high rpm startup idle for a few moments, rev it and it idles back down to 1300-1500 which I assume is normal idle...after I've been riding for a bit and I come to a stop light etc whatever, the bike idle is like 1500-1800????
If anything I would expect the idle after the bike has been running for a bit to be lower
Ideas?
What is the ideal ideal while waiting at a stoplight etc?
Goose
Old May 27, 2008 | 11:25 AM
StreetPower's Avatar
Default RE: Does this idle make sense?
i think it's not completely fine. mine starts cold at 2k+ rpm, then slowly drops to 2000, about 1800 .. 1500.. when it's all heat up , it's about 1200 rpm , after the stoplights too..
Old May 27, 2008 | 02:43 PM
maat's Avatar
Mine varies a bit for no good reason. It cold starts fine (2500 -> 2000 -> 1500), but warm start (> 100 degrees) it'll start straight at 1200 rpm which is sometimes a bit rough. Then after riding around for a while it'll hang at like 1500 rpm.
But this is the nature of open loop fuel injection. It's imprecise. The bike is trying to guess how much fuel is needed based on air mass and engine temperature. Cars have O2 sensors in the exhaust system to close the loop and give you that perfectly steady idle.
Old May 27, 2008 | 05:06 PM
you should have the o2 sensor too. and yes it should work close loop too...
Old May 27, 2008 | 05:16 PM
maat's Avatar
Nah, non-CA models don't have it
Turbulenz
Dec 29, 2009 09:36 PM
dont under estimate 1 liter
Jun 30, 2009 04:00 PM
VP
May 7, 2008 04:53 PM
CBRGazza
Nov 16, 2006 03:25 PM
jetson1000f
Apr 7, 2006 02:50 AM
