Resistors are POLARITY free, btw..if you have a series circut..then the current will be the same through all devices, resistors will drop voltage..all the devices in the circut will have the same current flow through them, and depending on the resistance of each device, will determine what voltage drop it will have..but all the voltages in the circut HAVE to equal the total voltage..so, say you have a 12 volt battery (conveniently enough) and you connect a resistor in series ( so, a resistor with 1 of the leads on the positive and 1 on the negative, doesnt freaken matter witch way!! You will have a 12 volt drop across that resistor. if the resistor is say 220 ohms, then the current will be..( using Ohms law..of E=IR...) 12=Ix220 ....I = 12/220 ==54.5mA. I = 54.5mA. So the current flow of this particular circut is 54.5 mA
seris cct, is like a train...chooo chooo!! everything is connected after eachother..1 lead to the next.
parallel is where there's a split between 2 leads..or more than 1 path the current can flow.. so, with ought getting way complicated, remember --Current stays the same in a series circut, period. ( Kirchhoff's current and voltage laws)..go here is you want < facstaff.bucknell.edu/mastascu/eLessonsHTML/Basic/Basic5Kv.html >
Voltage stays the same in a parallel cct. -- Just don't go having combination ccts, then the calculator is coming out...and no one wants to see that mamma jamma..its summertime!!
Nikos, what do you mean by measuring the resistance through the opener, when its open, ( like an open cct, theres no current flow, but all the supply voltage is on that 'open' )?? I don't want to call you out, but I don't understand what your trying to say...it doesnt sound right, but your on the right track...I am a sparky so dont take offense!
Oh My FCUK
Vortex Frame Sliders
CW FE
HB FM
K&N AF
HID lo/hi
No fat chicks
This ad is not displayed to registered members. Register your free account today and become a member on CBRForum!
We weren't saying resistors have a positive or negative, we were talking about hooking a resistor to the positive side of an LED or whatever you are hooking it to to make the voltage drop. Hook a resistor to the negative side of an LED and see if it will make a difference, I'll bet it will.
1996 Honda CBR 600 F3
Custom made front LED signals
Custom LED rear pegs
Custom Seat cowl
Aluminum mesh vent openings
Polished rim lips & stator cover
K&N filter
krusher, it shouldnt make a difference where you put the resistor in the circuit. the resistor will limit the current/voltage no matter if it is hooked up to the positive or negative source. components connected in series carry the same current as each other and each component experiences a voltage drop simultaneously, not one at a time.
try your experiment for yourself, it will be the same no matter where the resistor is, like sushi said. parallel is a little more complicated....
02 F4i Red/Black
-bootleg Slip-on
-BMC Filter
-PCIII USB - Two Bros Map
-954rr CA Taillight
-ZG Dark Smoke Windscreen
Actually, it will make a difference with an LED. The point of the resistor on an anode side of an LED instead of the cathode side is to limit the current through the LED to make sureyou don't burn it up.
Actually I took an LED today and put the resistor on one side then the other side and the LED lit up and did not burn up, no matter which side it was on. So as long as the resistor IS in series it will still drop the voltage and not "burn up" the LED. Didn't believe it till I saw it with my own eyes.
Custom Seat cowl
K&N filter
