Go Back   CBR Forum - Enthusiast forums for Honda CBR Owners > Current Honda CBR Models > CBR 600F4i
  #21
Old 11-03-2006, 01:41 AM
600f4i_blackout 600f4i_blackout is offline
Default RE: Repsol replica finished - pics - Updated
Simply gorgeous Billy, that's all I can say about the work... simply gorgeous
  #22
Old 11-07-2006, 03:23 PM
Jaybird180's Avatar
Jaybird180 Jaybird180 is offline
It rocks.
Track/Street 02' F4i
ZG Dbl Bbl, Galfer SS Lines, PC3r, Muzzy s/o, NRC cover, ShiftMinder(WTF?), Speedbleeders, Vortex sliders, fenderless, GP Shift, -1+2
Ohlins, Racetech, Showa Suspension
Because 12,000 RPM makes me feel better
  #23
Old 11-13-2006, 10:51 PM
XcesiveSlyd XcesiveSlyd is offline
Send a message via AIM to XcesiveSlyd
Hey dude, Sweet ride! I just decided to do the same thing to my 03 600RR. Just now. If you don't mind please give me all relevent information such as: colors, mixes, amounts, any stencils. I want my paint scheme to look the exact same. I'll post pics when its all done, inc. b4 and after. Thank you for any and all help provided.
  #24
Old 11-16-2006, 07:29 PM
CBRTerp CBRTerp is offline
I second what Xcesive said, I've decided to dismantle my bike also and do teh same paint scheme, could you PM me the relevent info and if I have any ?'s when doing it would you mind if I snet a PM your way?
  #25
Old 11-16-2006, 10:17 PM
leonend leonend is offline
great job on it man.....
  #26
Old 11-17-2006, 12:42 AM
ikhoudvanu199 ikhoudvanu199 is offline
hey, great job on the bike man, but, just wondering:
can u actually see anything out those mirrors? the look so tiny and close into the center...lol
  #27
Old 11-17-2006, 03:14 AM
JZHALES JZHALES is offline
SICKKKKKKKKKKKKKK!!!!!!!!!!!!!!
i love it man great job
my bike has character
  #28
Old 11-17-2006, 07:51 AM
BillytheKid BillytheKid is offline
thanks for the great compliments!
Right now we are in sicily for a long tour with our bikes. It is simply beautiful. When I come back home I will post details of the job.
Thanks
CBR 600 F4i- Repsol replica
Akrapovic exhaust
PCIII USB
K&N Filter
Gear changer indicator
Pro-Sprint stabiliser
Stock gearing Vortex sprockets, RK 520 Chain
MRA smoke windshield
undertail + hugger
PigSpotter mirrors
Scorpio alarm
  #29
Old 11-19-2006, 12:32 AM
JVracer04's Avatar
JVracer04 JVracer04 is offline
Send a message via AIM to JVracer04
what did u do for that running light between the headlights?
'03 CBR 600F4i
  #30
Old 11-19-2006, 03:29 AM
So finally we are back from our trip to sicily.... for those who asked me about details of the job... here is a run-down.
1) remove all the fairings from the bike
2) remove the decals with a hair dryer to soften the glue.
3) remove the sticky goo left behind from the decals - use a powerful engine degreaser and a fine wire brush.
4) sand down all the fairings with 400 dry grit until you achieve the flattest finish.
5) regarding the tank, you have to strip down the paint from the tank. Use a normal paint stripper to get down to the metal of the tank. If you plan to leave the tank for more than a week unpainted, cover the tank with a thin film of cooking oil to prevent rust.
6) buyin the paint. I had to mix my own to achive the desired colours however in the USA www.colorrite.com is the way to go. This is the link http://www.colorrite.com/CRPLfactory...mageField.y=10
Remember that what appears black is the pearl siren blue.
7) Buyin the decals. www.alloutgraphics.com, get the repsol scheme from them. However the sponsor decals of the side fairing are way too large to fit our fairings. So I had to order these individually from www.xtremedecals.com and chose the smallest size for each set.
8) stuff you need to order from honda before starting the job?? make sure if you need anything order it beforehand do order it NOW and not when teh bike is ready and you are wiaiting for that part to get going. One thing you will need for sure is the black rubber seal of the fuel tank pump because it is a single use item and you dont want a leak from there.
9) A few paiting tips - do not go spray cans... get a pro to do the job. Remember that bikes sustain a lot of abuse, us pressing our crotches on the tanks, flying small stones from the highway etc etc. The paint has to be strong and durable otherwise it will chip like nothing.
in most cases my sprayer applied 2 layers of white primer over all the fairing, 3 layers of base coat and 2 layers of lacquer, each time sanding with 600 wet grit in between each layer.
another important tip is where the large repsol decals sticks on the side fairing. The decal comes with the white background pictured. It is important to tell you sprayer that the he should fade away the line of transition between the red and the orange so that there isnt a line appearing beneath the white decal.
Regarding the application of the decals, dont you dare doing it yourself unless you know what you are doing. It is difficult to get them stuck round the curves and get them bubble free. Also remember that the decals must stick after the base coat application and that lacquer should be sprayed over the decals too to get that ultimate flat finish.
10) the rims were a hell of a headache. Remove all the disk crakes, tyre etc. I would advice you to sand them down till you get to the metal. Spraying them is a 2 man job. Make sure you mask the bearings. Put the rim on a rod through its axle. While the syrayer is spraying , someone should rotate the rim to avoid paint from dripping to the sides.
11) rear sets, passenger pegs and forks - same as above, I used a matte black finish on them.
I cant remember of anything else, if you have any questions just ask on this thread.
Jvracer 04 - the running light is standard in the european model.
Akrapovic exhaust
PCIII USB
K&N Filter
undertail + hugger
PigSpotter mirrors
Scorpio alarm
05, 2001, 2002, 600, cbr, decal, f4i, honda, map, mirrors, pics, pig, replica, repsol, spotters
