Go Back   CBR Forum - Enthusiast forums for Honda CBR Owners > Honda CBR Forum Sponsors > CBR Zone
Old 06-23-2006, 10:41 AM
blade17fire blade17fire is offline
Default camshafts and wat else??
For a serious hp gains..I think I read somewhere dat camshaft and cams are the way to go..Dun really noe wat these are anyway..LOL
My question is..If the owner decides to go with a camshaft mod on his 1000 rr, wat are the other component needed to execute this mod?? ie; with juz a camshaft can the mod be done or they need added springs or watever or watever or watever...blah,blah,b
GPR Thunderline Exhaust
BMC air filter
Hodaka V stacks
Flapper mod
PC III
AFAM Sprockets
HID Headlights
HRC Clutch Springs
HRC Cam Sprockets
HRC Engine Power Up Kit III
HRC 1/6 Turn Throttle
Ported and Polished Cylinder Head
Old 08-30-2006, 02:11 PM
1000RR 1000RR is offline
Default RE: camshafts and wat else??
Don't know about "serious" gains, but most race spec camshafts are worth 5-6rwhp, mostly all at the top end (10,000+rpm).
What all you need depends on what you get.
For Example, Erion Racing claims their cams are drop-in replacments. They keep the same profile etc, so you don't even need to re-shim the valves. You just buy them, install them and *poof* extra zip up top.
You also have:
Webcams
HRC Cams
Tornado Cams
HRC has several different versions as well... JSB, WSB, Enduro, etc...
Some will require valve springs and/or ECU to raise the rev limiter high enough to benifit from the new power curve.
You're gonna be looking at spending about $1000 for a set of cams... so if thats worth 5-6hp, go for it.
The first thing to do would be get a Full Ti Exhaust system. A good one (~$1200) will add 10-14hp AND save 10-15lbs. Thats alot more bang for the buck.
Old 04-28-2009, 02:10 AM
chasetheace08 chasetheace08 is offline
Lightbulb
YOU REALLY only need to change cam shafts. Basically what your doing with the cam shaft is just changing the duration that the valves are open. (so if you get bigger cam lobes your just allowing more time for the valves to open to do there job.)
if you need any additional info let me know.
125, 954, cams, camshaft, camshafts, cbr, cbr1000rr, cbr900rr, erion, honda, hp, hrc, motorcycle, performance, racing, tornado
