Tripage cruise control
Hi all! I just fitted a cruise control to my 2002 CBR 600 F1 and it works a treat! You can get one for your Honda (most models) from: tripageLED.com. I paid $70.00 for mine and it was easy to fit. Basically you remove the vibration damper from the inside of the throttle handle bar and insert the included mounting piece for the new bar end weight. The new bar end screws on anti clockwise thereby causing friction against the throttle twist grip end when you turn both the throttle and the bar end together and holds the throttle open. Simply shut the throttle off and the grip slackens off again. Watch the video on youtube or on the maker's website. Go to www.tripageLED.com and look for 'cruise control' down the left hand side of the page. Just wish Honda had fitted one as standard!
