NC29 Project
NC29 Project
It all started the day I came off my NC30........
Eventually I managed to get my paws on this NC29, which apparently was previously looked after......
Anyhoo, When I started stripping, the more I stripped, the more I had to fork out.....
-Stripped the fairings, the Air ducts were cracked and fibreglassed on the inside...it woulda been somewhat okay if they were done properly...
- Front forks were leaking badly
- Front brakes werent very effective as the forks were leaking onto the brake pads
-The bolt that needs to be removed to get the brake pads out was stripped so I cant get the pads off
- Rear Caliper Ceased, so it needed a bit of elbow grease coming off.
- Subframe was slightly rusted, I removed that and will be prepped for some paint.
- Brake fluid Resevoir leaking
- Accelerator cable snapped
- Screen Cracked
- Kick stand bent
- Clutch cable from an NC23, so it's slightly longer.
Looks like I have my work cut out for me.
- Screen Cracked
- Kick stand bent
Just got a call to say that the forks are bent and the previous owner was a Retard as the sliders are more useful ornaments now EPIC FAIL......managed to get my hands on NC23 Hurricane sliders, and they look to be identical......the helpful gentlemen at the local bike shop is busy servicing them, replacing seals, oil etc.......
