tyre pressure
Old 07-26-2016, 03:38 AM
wessa's Avatar
Default tyre pressure
no owners manual,so i got to order,looking for the correct tyre pressure,bike came with Maxxis tyres which i hear are bottom of the range (correct me ).
max psi on side wall is 42 psi but reckon should stick to manufacturers guidelines,what ever they are ?
can anyone help with the 250/290 explaination.
Old 07-26-2016, 05:22 AM
74demon's Avatar
42 psi is good. You can run a little lower if you want, depending on what kind of riding your doing.
The 250/290 is the pressure using kPa scale.
Old 07-26-2016, 05:53 AM
Gazz's Avatar
The 250 and 290 will reflect back to front and rear tyre as well and again indicating that the same pressures will be used irrespective of one rider or one rider and pillion
Old 07-26-2016, 05:55 AM
Gazz's Avatar
Furthermore the 250 reverts to 36 psi in the front and the 290 reverts to 42 in the rear tyre going on their recommendations
Old 07-26-2016, 06:20 AM
wessa's Avatar
thank you,it has been very helpful and i will make some adjustments,checked yesterday on cold tyres and it was 35 front and 38 at the back.
at least i undestand the sticker
Old 07-26-2016, 06:26 AM
Gazz's Avatar
Not knowing where you are but just remember beer these are a guide by the manufacturer
You can also take into consideration the temperature that your riding in and the distances.
If its stinking hot and your ducking to the shop 2 minutes away is very different to hot roads and riding ten hours so adjust accordingly
Old 04-02-2017, 04:01 AM
RAMOZTR's Avatar
Default Hot Climate
Hi all
I just bought a CBR600F 2013 Model..
I live in Turkey and the weather here is hot.
so should I stick according to the manual tire pressure or what would be the best.
I will try 34 -38 or maybe 34 - 40...
What is your recommendations?
Old 11-03-2019, 04:05 PM
cleeve555's Avatar
New Member
Confirmed front 36psi and rear 42psi when hot, work well, on a CBR600F 2012
bigz954
09-23-2007 09:07 PM
waz57
07-09-2007 03:30 AM
hkwiz
05-24-2007 12:36 PM
png13
09-22-2006 04:31 AM
Silent Bob
02-17-2006 03:31 AM
Quick Reply: tyre pressure
