How To's Show us what ya did and how ya did it!
Manual CCT Mod
Old 07-05-2009, 06:07 AM
Shadow's Avatar
Thanks for this - I'm sure some of the guys will be really keen..........
Old 07-05-2009, 06:15 PM
raiden's Avatar
there's other way that no need to welding it, all u need are screw, nuts and steel plate, what u have to do is bend the steel plate twice and make a hole on it.. here's my sample..
Old 07-07-2009, 10:49 AM
Sprock's Avatar
Exclamation yeah Raiden.....they'll all be custom works of art !!!!
Here's the tensioner I'll be going with from Kwak 900
It has a ratchet tensioner at the tip and a wider foot
The spring can be taken out easily.
The ratchet prevents slack under severe engine breaking
My
Also
My bike shop were not impressed with this stuff they'll
only entertain the crack the case Honda chain loop
routine..........figures ..........$$$$$$ !
They did say they've done a few where they "shaved" down
the tensioner ?? Had to leave at that point, but will find out
what they meant by that exactly. Probably the chain runner
rethread kinda thing I suspect
Old 07-07-2009, 04:44 PM
raiden's Avatar
there's no mod for that tensioner, i suggest use thicker spring that exactly fit to the hole and make sure the edges will bounds and i think that skinny spring will shrink faster than the thicker one and it cause noise friction... i suspect
Old 07-07-2009, 07:44 PM
Sprock's Avatar
You are dead right there Raiden.........but well there will be
Like I said each will be custom I'm sure. I plan on having a spare tensioner
bracket/frame assembly on which I can cut,weld and experiment on first.
I plan on this tensioner, the spring does not have to be super heavy in this
design the ratchet does the work
Never say never
Old 07-07-2009, 10:36 PM
raiden's Avatar
i heard some ninja rider about this tensioner problem that if the tensioner spring is off or broken .it cause noise.. i dunno if he telling the fact..
Old 07-08-2009, 11:24 AM
Sprock's Avatar
yep tensioners are a fairly universal problem. maybe A manual APE tensioner
might be better as Shadow mentioned ............we'll see .............
Quick Reply: Manual CCT Mod
