Cam Chain & Tensioner Replacement - HOW TO - by Naga Thai
#21
Kudos to the man that posted this , very VERY good, everyone has been totally spoilt with this guide.
Right ,i'm about to do this job on my 88 CBR1000f,question,I have bought new tensioner kit :CCT
Kit 04102-MM5-010 But ,I'm a bit confused as to whether I need the two extra parts : (oil guide and plate) ? My local bike shop (Very good) can not find the two parts listed with Honda,do I need them ? I'm really not sure?
Thanks in advance.
Thanks in advance.
#22
Thanks in advance.
Thanks in advance.
If you bought the kit you mention then the parts (oil guide and plate) should be included in with the installation. You have all you need.
Take your time with the job - enjoy the pleasure of the experience and the reward of the result.
#23
Thanks for the quick reply.No need to thank me my friend, Credit where credit is due !
I picked the parts up earlier, no oil guide or plate in the box, just two bags, tensioner and large cover plate (I assume) .I even questioned the guys there having seen the two extra bits in the guide written by you .They searched but could'nt locate the part numbers.They were convinced everything in the box was all I needed, really not sure now.Where do the parts fit? Could they be attached already to the parts I have do you think ?
Mark
Mark
#24
#25
Mark
Mark
Yes - you will need these parts.
The oil guide parts were part of the upgrade after 1987/88. They direct oil to the cam chain. See the retrofit instructions from Honda on attached page 3 (remember to remove the 2 washers - as instructed - when fitting).
You ask.. "Could they be attached already to the parts I have do you think ?" NO. YOU WILL SEE THEM SEPARATELY IN THE PICTURE I ATTACH.
The time you will NOT need them is if the CCT had been replaced before; then the oil guide SHOULD have been inserted/installed then.
Attached are further details - pictures - in a 6 page pdf I made for you. http://db.tt/cGkZqP8q
#26
Hello Naga_Thai,
Great write up man, followed your link from YouTube and downloaded the PDF, great resource to have. Am currently trying to download the PDFs for PREPARING REPLACEMENT CAM CHAIN, WHEEL BEARING FRONT, WHEEL BEARING REAR and CARB SYNC using the links on your signature. Unfortunately every time I click through, Internet Explorer stops working (broken links?) Anyway, is there anywhere else I can get copies from?
Am hoping to have my 93 model all ready to rumble for the local toy runs around November-December. Have fitted new brake discs/calipers/lines, New rubber on the front, new rear rim waiting for blast/powdercoat and bearings. New plugs/filters/fluids are awaiting financing along with chain and sprockets.
Any advice/help you could give me would be well appreciated!!
And yes....
And yes....
#27
I have to say, that this guide helped me greatly. Thanks Naga Thai. I was very concerned about doing this, but having worked on vehicles since i was 14, i was relieved to see this. I got it done without a hitch. I did have a friend come by, and check my timing marks before buttoning it up. Just a safety measure.
#28
#29
Hello Naga_Thai,
And yes....
And yes....
#30
Hi Happy!
You should use the latest cam chain tensioner with the latest part number. (not 1987 part number.).
FYI, my recommendation is as per the pdf you have read ...
CAM CHAIN AND TENSIONER REPLACEMENT
Parts you will need:
1. CHAIN, CAM (150L or more) 14401-MM5-015 ( Or DID equivalent )
2. CHAIN, CAM joining link.
3. BRACKET, TENSIONER 14500-MZ1-000
4. TENSIONER ARM PIN,HP-14531-KV0-000 14531-KV0-000 – QTY 2
5. PIN (6MM), HP-90607-MM5-000 90607-MM5-000 - QTY 2
6. SLIPPER - HP-14510-MM5-640 14510-MM5-640
7. GUIDE B, CAM CHAIN 14630-MS2-610
8. GASKET, CYL HD CVR, HP-12391-MM5-000 12391-MM5-000
I also recommended
1. O-RING (7.5mmX1.5mm) 91302-HB3-004 - QTY 2
If you have a 1987 or 1988 and are unsure if it has had the CCT retrofit (CCT
Kit 04102-MM5-010 ) then you will need these additional parts <See Appendix
at end> :-
1. PLATE, 14542-MM5-000
2. PLATE, OIL GUIDE 14541-MM5-011
I also recommended
at end> :-
Would like to see a picture of the parts mounted in the right place.
