How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Regulator(Reg)/Rectifier(Rec) Cooling Fan install
Old 07-07-2014, 09:45 PM
entity-unknown's Avatar
Default Regulator(Reg)/Rectifier(Rec) Cooling Fan install
This fan turns on only when the kick stand is up i.e. when you need it. Other methods can be chosen but I found this to be the best hassle free setup.
Summary: You wire the positive to the battery with a fuse and on/off switch and the negative goes to a on/off based negative source. The kick stand cut off switch is the best choice for the F2/F3 here and is mostly universal but every bike can be different.
The meat n potatoes:
This is how to is specific to the F2 however this applies to the F3 and really any motorcycle that has a regulator/rectifier and uses a kick stand cutoff with the negative wire being the effective wire that goes on/off. The core concept is to wire the fan directly into the battery for the positive terminal, and the kickstand shutoff negative for the negative terminal.
Things you'll need:
a PC fan that'll fit with your Reg/Rec (10MM with finned Reg/Rec for most bikes)
PC fan case screws
inline fuse block (optional but wise idea)
battery charging terminals from battery tender with multi-terminal connector that has a ring set and a standard clip on set. Walmart/any parts store carries these.
Hookup wire
shrink wrap
electrical tape (optional buffer for shrink wrap)
Bridge terminal connector (optional but best option)
On/Off Switch (optional but necessary without a kickstand and useful with)
I chopped the clip on (same type of connector used for jumping auto) charging wire that plugs into the battery tender's connector wire and I use this to wire the positive wire for the fuse.
I wire the fuse to the On/Off switch and mounted that in the convenient area closest to the reg/rec.
I then wire the lead out from the On/Off switch to the fan with the negative wire hanging there unconnected.
Next I connect the ring style charging cables from the battery tender to the battery like you would normally do if you were to use a battery tender. You now have a battery tender wiring setup too that you can swap in for the fan when not stored.
Now you find the kick stand cut off switch. The Honda CBR F2 uses the negative wire as the on/off hence why I chose this wire to bridge into.
You can use a terminal bridge, or scrap off some insulation and do a solder joint. This is up to you and what you can work with.
Once the negative wire is connected into the kick stand cut off switch, and the positive with fuse link is connected from the battery terminal tender o-ring style connectors, you're now done!
Attached Thumbnails Regulator(Reg)/Rectifier(Rec) Cooling Fan install-dsc01727.jpg   Regulator(Reg)/Rectifier(Rec) Cooling Fan install-dsc01729.jpg   Regulator(Reg)/Rectifier(Rec) Cooling Fan install-dsc01728.jpg
Old 07-07-2014, 11:43 PM
CorruptFile's Avatar
June 2013 ROTM
Good mod. One of those ones that if it was designed correctly in the first place, we wouldn't need to do this. Good thinking with the sidestand switch. Alternatively, you can patch into the ignition and run it that way. That way you are pulling a fused +12V and don't have to wire to the battery.
Old 07-08-2014, 06:16 PM
Thanks and totally agreed on proper engineering... I'm double screwed living in AZ so the fan is a must for summer and sustained high RPMs.
Ignition isn't a bad idea either. I didn't want to risk pulling anything on that circuit not cut the wire but I did consider it. Another idea would be to wire in a capacitor and diode to ensure spike back into the system and a clean charge to the fan but so far that seems over board from no issues in the 4 years I've had this installed.
Old 04-07-2015, 10:56 PM
fishdewd's Avatar
Perfect time for me to see this, thanks for posting. I just got my R/R in from China, hopefully not a cheap POS, It looks pretty much OEM which we all know have overheat issues, I am a PC Technician by trade and definitely have more cooling fans around than I know what to do with, at least now I know what to do with at least one of them.
Old 04-12-2015, 12:13 PM
Def and hope it helps you out!
So I've had this fan for around 5 years now and I still have the same Reg/Rec after the same 5 years and no issues. It's been through track n some brutal summer rides in AZ but it's never burnt me like it used to when it would die every summer. I definitely recommend this mod!
Monkeybutt2000
06-21-2011 12:49 PM
NYKnick1015
07-23-2010 11:57 PM
raiden
07-08-2010 09:18 AM
kcinobro
03-30-2008 07:30 PM
Quick Reply: Regulator(Reg)/Rectifier(Rec) Cooling Fan install
