How To ... This section is to tell 954 owner's How To do something ... not for asking questions ...
How to change your 954/929 Oil
Old 03-02-2011, 05:57 PM
txsmainevent's Avatar
Default How to change your 954/929 Oil
By request of davpan12, here is a quick how to. I don't currently have my engine in the frame and fairings on. Pretty much self-explanatory.
1. Remove right side lower fairing. No pics of this process. Its too easy.
2. Locate oil drain plug circled in red, remove and drain oil. After oil has finished draining re-install drain plug.
3. Locate oil filter, in the front of the engine behind the headers (headers DO NOT NEED TO BE REMOVED, mine are). Remove filter and drain oil.
4. With filter is 3.9 Quarts of oil. Put a small amount of oil in filter and install.
5. Fill oil with whats left of the 3.9 quarts of oil.
6. Re-install fairing.
7. Done.
Old 03-06-2011, 01:27 AM
HONDA-BG's Avatar
Default perfectly
i should change my oil ,i bay a MOTUL 7100 ,this is a nice post whit a pic. thanks for this. I use this
Old 03-06-2011, 11:39 AM
ominous1's Avatar
a little tip when removing the filter, I lay a little peice of cardboard on top of the header under the filter. that way i dont have to smell the spilled oil.
Old 03-06-2011, 01:11 PM
letsride's Avatar
If you do spill oil on your headers,I would use brake cleaner to remove it.
Old 03-09-2011, 05:51 PM
davpan12's Avatar
Your to awesome =]. I really appreciate this bro
Old 03-31-2011, 11:30 PM
TheYellowDart's Avatar
Do you all torque down your oil filter to 20 lb-ft or just hand tight? It's really hard to get a tool in there with the headers on, and I would probably have to buy one if I wanted it to fit on my torque wrench 3/8" drive. I did mine today and just did hand-tight like other bikes I've had. But the service manual calls out 20 lb-ft which sounds like significantly more than hand tight.
Old 04-01-2011, 09:14 AM
All my filters (bike, car, truck) are hand tightened. I hate trying to get a filter off that a service center torqued down. No leaks yet.
Old 04-02-2011, 09:14 AM
Yeah. I only had a little leak once on my Multistrada 620. I noticed a spot of oil under the bike and gave the filter another good twist. Then it was good until I changed it about 2000 miles later. On a bike with a lower fairing though, you might not notice for a while, which could be bad.
I'd hate to have to buy a tool though just for the oil filter on this particular bike. And yes it did take a pipe wrench to get the old filter off. I was afraid I would tear through the filter before it loosened.
Good writeup! Do you also put old oil around the seal of the new oil filter before putting it on? That's what I have been told to do.
Old 04-02-2011, 09:44 PM
davpan12's Avatar
You should always put old oil around the seal of the new oil filter if its for a bike and even a car. It allows you to take it off easier and to put it in easier. Always put oil on it and make it a good habit
stealthCBR929
05-24-2012 03:15 PM
89HurricaneF1
05-07-2012 09:52 PM
michealparks
02-10-2010 12:16 PM
fiveoh
07-08-2008 10:43 AM
otisdr
08-07-2006 06:51 AM
Quick Reply: How to change your 954/929 Oil
