Wrong regulator rectifier cbr600f2
Hey guys i'm new here and need some help with my bike. i recently bought a cbr600f2 and ive been finding out that this thing is just cobbled together runs alright when it runs but im having a problem with the battery dying. i did some searching and found out i have the wrong regulator rectifier on there. seems the person i bought it from spliced some wiring and put the wrong part on there i wanna know if i can make this work. the black wires coming from the top are going to the battery's positive and negative posts i feel like the wires from the original connector should be going into this thing but there is no part number so i have no idea which would go where or even if thats right i know its a shot in the dark but maybe one of you have seen something like this before, anything will help thanks.
A lot of F2/F3/F4 guys switch to a gsxr regulator, and they hardwire it. All regulators do the same thing, so the only issue is whether or not your R/R can handle the load of the stator, and making sure its wired correctly.
Do you have any pictures of it? You say spliced, I hope you don't mean with butt connectors, that would be...not great... And you should try to identify it so you know what you have and if its capable.
Don't automatically dismiss other parts being on your bike, right away. Sometimes, its an upgrade. I have parts from all the big 4 on my bike...
The two wires that are not being used as is are indeed what the two black wires should be connected to. The green is a common ground, and the red/white is going to the battery VIA THE MAIN 30AMP FUSE which is now being bypassed, you don't need to be a rocket scientist to figure out that is a bad move. Also all twist n tape connections should be immediately soldered and the person that has made them nutered. There are some pretty big currents flowing there and a bad connection starts to easily heat up. To the question why is your battery going flat, do you have a multimeter? Test what the pole current in your battery reads while idling, does it go up while revving and how much. Those bodged up connections can at least partly explain why it's not charging properly. As said the original reg/rec does not have fins and it's a common upgrade to swap another one in that does.
First off solder the wires, cut the leads going to the battery and attach the one that goes to the + pole to the red/white, and the one that goes to the - pole to the green.
Trips
11-06-2012 10:25 AM
